Explore OVHcloud Storage and Backup Solutions
The data you store and its various uses may have specific constraints, requiring an appropriate solution. OVHcloud offers cloud storage solutions to suit your needs—from object, block, or file storage to long-term archiving space and backup solutions for all your services. This way, you can store, organize, present, and preserve your data to best suit your needs.
Object Storage
With object storage, you can store data in buckets as objects (rather than as files or blocks). This type of storage is perfect for large volumes of unstructured data, such as images, videos, and audio files.
Block storage
With block storage, you can divide files into data blocks and store them on independent disks attached to your instances. You can also add or remove disks as required. This type of storage is perfect for virtual machines and transactional databases.
Archive storage
Archiving is specifically designed for very long-term data retention requirements (e.g. medical records, legal documents or government archives). This type of storage is designed for data that does not need to be accessed regularly and quickly.
Backup
Backing up your data is an essential part of ensuring that your business remains up-and-running. You can use it to secure your data by creating a copy of it, and setting up a disaster recovery plan. We offer solutions adapted to meet every need, so that your business remains online.
