Try OVH cloud services today.
Get started now.
Accelerate your business, automate your infrastructure
OVH Public Cloud offers you an extensive range of cloud solutions, billed on a pay-as-you-go basis, and set up in a simple way that supports your projects. Take advantage of the flexibility of on-demand resources to scale up from small projects to large-scale deployments.
Discover our products
Compute
Guaranteed Resources
Deploy cloud instances with fully-guaranteed resources that cover a very wide range of uses
Sandbox
Access small instances with shared resources at a low cost, perfect for test and development environments
Storage
Block Storage
Create storage volumes, which can be used as additional disks and secured via triple replication of data
Object Storage
Enjoy unlimited on-demand storage, accessible via API
Cloud Archive
Archive your data over the long term while keeping it accessible via standard protocols
Volume Snapshot
Trigger a snapshot on your Block Storage volumes
Backup Instances
Get a backup service for your instances
Network
Private Network
Deploy private networks, supported by the OVH vRack, to connect your instances across the globe
Anti-DDoS
Enjoy permanent protection across all your cloud resources, to ensure an optimal level of service
Containers and Orchestration
Managed Private Registry
Soon
Manage a repository for your software bricks in the form of Docker® images or Helm® charts
Workflow Management
Automate your tasks to manipulate your cloud resources, based on your business logic, to address each situation
OpenStack Orchestration
Beta
Model and deploy your infrastructure in code form to accelerate your deployments and other pre-established scenarios
Public Image Catalog
Get dozens of cloud images, provided and managed by OVH, ranging from simple system images to pre-installed applications
Private Image Catalog
Maintain and store personalised images of your virtual servers within your private catalog.
Management Interfaces
Horizon
Use the original OpenStack web interface to effortlessly manage your cloud resources
Physical Remote Control
Use KVM consoles to connect directly to your cloud servers
OpenStack Client
Manage your command-line infrastructure with the official OpenStack client
OpenStack API
Utilise the standard OpenStack API, which is fully compatible with a wide range of tools on the market
Launch your first cloud resources in minutes
A cloud service adapted to your needs
Whatever your needs, our Public Cloud offers you a range of management interfaces: API, CLI, orchestrator or web interface.
Manage your services with simple orchestration tools ![]() |
Control your cloud resources via the OVH Control Panel ![]() |
Why Public Cloud?
OVH Public Cloud has a highly-competitive price/performance ratio. In addition, we always guarantee predictable billing and full reversibility.
Main Features
Pay-as-you-go
Use cloud resources with no commitment and get a bill that reflects your actual usage. You don’t need to anticipate any servers or storage you may need: just create the resources when you need them and then delete them when your project is complete. We only charge you for your actual usage.
Simple and transparent billing
Your resources and services are grouped into projects, allowing you to segment your uses according to your business needs. At the end of the month, a bill per project is generated, allowing for simple and clear administration. You can also get a usage forecast and set up alerts.
Standardized APIs
All Public Cloud services are accessible via standard APIs available in the cloud computing sector. OpenStack for Infrastructure-as-a-Service (IaaS), Kubernetes for container orchestration, etc. So you can program your cloud resources through the tools that suit you.
Prices
Public Cloud is a very affordable, high-performance platform. The range of services and the flexibility of resource sizing allow you to manage your usage in the best way possible, depending on your needs. We pay particular attention to cost predictability. We don’t charge for services beyond your control (storage processes, API calls, etc.).
Support and Documentation
Why choose Public Cloud instances?
Public Cloud instances (virtual servers) combine flexibility and guaranteed resources. In minutes, you get CPU, RAM and storage with no resource over-allocation, as well as root access. OVH Public Cloud offers hourly billing and a number of features such as the ability to add resources without having to reinstall. The OpenStack API lets you automate your infrastructure.
Which cloud solution is right for you?
There are different types of cloud models available, depending on your needs. These include: IaaS (Infrastructure-as-a-Service), which gives you access to a range of services including severs, storage and networking, PaaS (Platform-as-a-Service), which provides the user with hardware and software freeing users up to focus on installing and running applications, and finally SaaS (Software-as-a-Service), where you simply use software over the internet and have no management tasks.
High availability, simplicity, flexibility and reversibility
Our Public Cloud is hosted in our data centers, on servers assembled by our technicians, for high performance and total control, from manufacturing to provisioning. Public Cloud is very intuitive to use, and it’s flexible, so you can adapt it for your specific projects. But that's not all. Because we use standard APIs, your data is reversible, and our products are interoperable, so you can set up a hybrid cloud.
