US OVHCloud Deals Logo
Check out our deals on select dedicated servers
From $69/month. Offers end June 9, 2020
Dedicated servers
Home sd
Choose the best infrastructure for your business applications
With OVHcloud™, you get our full range of expertise regarding bare metal solutions. All our servers use next-generation components. Each machine is designed and assembled by us.
We offer different ranges of highly-efficient dedicated servers, adapted to the most demanding needs of any type of company.
With just a few clicks, you can host your website, deploy your highly-resilient infrastructure or customize your machine.
When you store data on our secure infrastructure, you benefit from a highly available server for your critical uses.
Our dedicated servers ranges
Start with your first server
Rise Dedicated Servers
Dedicated servers in the Rise range are the most affordable bare metal servers offered by OVHcloud, and are based on a Intel® Xeon® platform.
From
$69.00 /month
illu_adv
Advance Dedicated Servers
The Advance range is designed for small businesses that want to invest in versatile servers that fit their business needs.
From
$86.00 /month
Serveurs dédiés Infrastructure - OVH
Infrastructure Dedicated Servers
The Infrastructure range includes the OVHcloud private network (vRack) and features powerful processors allowing you to build infrastructure in complex environments.
From
$112.00 /month
Serveurs Dédiés Haut de Gamme
HG Dedicated Servers
The HG range allows for powerful, fully customizable configurations specifically designed for critical or resource-intensive environments.
From
$355.00 /month
Best Value Server
Best Value Dedicated Servers
OVHcloud Best Value is a great way for you to experience the advantages of bare metal over virtual servers at an unbeatable price. Our Best Value bare metal servers feature the most stable environment, making it perfect for processing large volumes of data.
Game
Game Dedicated Servers
Servers in our Game range included DDoS protection up to L7 allowing you to securely host your online games.
From
$101.00 /month
How are OVHcloud dedicated servers different?
Performance
When you choose a dedicated server, you can rest assured that all resources are allocated to you for maximum performance. Our servers are designed, assembled, and maintained by our teams, in order to offer you optimized configurations for your projects.
Availability
Deploy your servers in minutes in our 28 data centers around the world. You benefit from a secure, high-resilience network, to ensure continuity of service for your customers.
Scalability
By creating an infrastructure with OVHcloud dedicated servers, you can build a reliable technical platform for your business applications. The scalability of your infrastructure is further enhanced by the ability to interconnect your servers with other OVHcloud solutions, such as Private Cloud and Public Cloud.
Sustainability
By hosting your servers with OVHcloud, you benefit from innovative and unique solutions across our entire infrastructure, such as water cooling for energy efficiency.
Included with your dedicated server
Bandwidth and unlimited traffic
Each OVHcloud dedicated server has a minimum public bandwidth of 500 Mbit/s, with a burst available to absorb occasional peak traffic. Incoming and outgoing traffic is unlimited and free. You also have the option of increasing your bandwidth capacity, if necessary.
OS Distributions
Many distributions are offered for automatic installation via the OVHcloud Control Panel. This includes various operating systems (Windows® Server, Debian, Ubuntu or CentOS), Plesk and cPanel Web management interfaces, and Microsoft® SQL Server for databases. Virtualization solutions, like VMware®, CoreOS and Windows® Hyper-V, are also available.
DDoS protection
To provide maximum security for your infrastructure DDoS protection is included with your OVHcloud dedicated servers. It ensures the continuity of service of your applications in case of attack.
Assistance and support
By hosting your servers from OVHcloud, you benefit from technical support via chat available Monday-Friday from 8am-8pm EDT. In addition, a range of guides and an online Help Center is available to assist you during the installation and administration of your services.
Find out more about the OVHcloud dedicated hosting solution
What is a dedicated server?
A dedicated server, or computing server, is a server where all the physical resources of the machine are available. Unlike a virtual server, which uses a portion of the resources to run its virtualization technology, a dedicated server allows you to benefit from all of the machine’s available RAM, storage, and computing power. With cloud computing, we can also define this type of solution as "bare metal", highlighting the physical availability of the machine’s resources, in contrast to standard solutions based on virtual instances.
Which dedicated server should you choose?
The configurations used for our dedicated hosting solution are designed to suit professional needs. Depending on your usage, you might need a configuration with more RAM, bigger storage space, or a higher processing capacity. Furthermore, the different OVHcloud dedicated server ranges are distinguished by their bandwidth capacity and range of associated services. You can also get anti-DDoS protection adapted for online gaming, a private network (vRack) with up to 10 Gb/s to allow you to connect your dedicated server to your infrastructure, or even hardware RAID. Choose the dedicated server that fits your needs.
Cloud, shared hosting, or a dedicated server?
There are two main factors that make a dedicated server different from a cloud instance. First, the machine's raw performance is different: there is no virtualization layer consuming resources on a dedicated server, so you are guaranteed full use of the physical resources. The second difference concerns the level of server administration. With a dedicated server, you manage everything from its configuration to the data hosted on it, and you are also responsible for ensuring that it is secure. It will therefore give you the option of a more advanced installation, which is essential for the use of certain business applications. The main benefit of a dedicated solution is the total freedom you enjoy as a user. However, if you would like to avoid technical management and concentrate solely on your web project, then OVHcloud Public Cloud instances are the best solution for you. Just need to build a simple website? Take a look at our shared hosting solutions, which offer you a hosting platform at an unbeatable cost, with the configuration fully managed by OVHcloud.
What can a dedicated server be used for?
There are many uses for a dedicated server: big data, machine learning, website and application hosting, backups and storage, infrastructure virtualization, server clusters, business applications (CRM, ERP), and even online game hosting. This is why we offer several different dedicated server ranges, each of which are designed for a specific set of needs. Our sales and support teams will help you with your project, and can offer expert advice on which server to choose.
