Logs Data Platform
Logs Data Platform
Increase visibility into your applications' environments by collecting, processing, analyzing, and storing your logs in a full-featured, managed platform. Log analysis is vital in keeping your infrastructure and applications up and running.
Why choose OVHcloud Logs Data Platform?
Standard and reversible
Benefit from the full OpenSearch (OpenSearch Logstash OpenSearch Dashboards) ecosystem, while using your existing tools; including Graylog, Grafana, Flowgger collectors, and Filebeat. Leverage our hardware-agnostic platform to send your log file from any cloud provider, or on-premises clusters.
Powerful and scalable
This complete platform enables the collecting, indexing, storing and analyzing of logs. Store and process your logs on a highly available and scalable infrastructure. Our Logs Data Platform combines the performance of OVHcloud infrastructure with the power of OpenSearch - providing sub-second search results.
Comprehensive pricing
Benefit from a complete, pay-as-you-go log-management solution. For advanced usage, you can simply add options to your platform. With predictable pricing and unlimited traffic, you'll never be surprised by your monthly bill. Take advantage of thresholds and alerts to improve your consumption efficiency.
Security and Industry Standard
These services are built to follow globally recognized security practices. This ensures that comprehensive security measures are in place to manage risks, address vulnerabilities, and protect sensitive information. Logs Data Platform is compliant with ISO/CEI 27001, 27017, 27017, and 27701.
Use case examples
Troubleshoot your application in real-time
Developers can analyze how their application is behaving, and perform root cause analysis and troubleshooting procedures to help them improve their code, all in real-time. They can also take advantage of Live Tail to stream their logs in real-time, and to connect different applications or servers to one unique endpoint (making all of them appear in one stream if necessary).
Monitor & SEO analysis
Logs Data Platform offers powerful log analysis tools to monitor your website. Indeed, the analysis of Apache and SQL logs is a proven and recognized method in this field. For example, you can use Apache logs to study the activity of your visitors, the delivery time of pages, the results of the code, and the agent used to access your site. SQL logs can, for example, allow you to identify queries that slow down your website. In addition, you can use the alerting function to receive a warning in the event your website goes down, is too slow, or is displaying an error 500.
Secure legal logs
Regulations may require that you keep logs relating to the traceability of customer data over a long period of time. Our cold storage options help you ensure compliance (check our tutorial here). If you need to access these logs quickly, then choose the "Immediate withdrawal Cold storage"; otherwise choose the "Economical Cold storage.
SPECIFICATIONS
Technical Specifications
Dashboard
Grafana and Graylog
RBAC
Included
Alias OpenSearch
Included
Logs stream
Graylog
Standard Protocols
GELF, Syslog, Cap'n Proto, LTSV, RFC 5425, etc
Data encryption
TLS encrypted log transfers
Alerting
Included
API calls
Graylog and OpenSearch
Flexible retention
14 days / 1 month / 3 months / 1 year
Our Logs Data Platform range
Available Options
Browse all our available options: Discover
Generate a daily archive of any stream and keep your log files for 1, 2, 5, or 10 years with two options: Economical or Quick Cold storage. Choose your compression algorithm: gs (zlib), zip (deflated), 7z (lzma-2), or zst (>=1.2).
Dedicated Dashboards
Create interactive and personalized dashboards, with real-time data. Monitor your environments with granular visualization capabilities. Ensure the isolation of your log with our dedicated OpenSearch Dashboards option.
From
Logstash & Flowgger
Isolate your streams for maximum availability and scalability with dedicated Logstash or Flowgger collectors. Our data-gathering tools make it easy for you to process your data regardless of its source, format, or structure.
From
Index as a service
Store and query complex documents, reports or logs with tools from OpenSearch Ecosystem (Grafana, Fluentbit, ElastAlert). Configure the number of shards per index: up to 16 per index, 25GB maximum per shard.
From
Documentation
Get started
Use cases
Security and conformity
All guides and tutorials
FAQ
Why are logs important?
Log files are created every time an event occurs on your IT systems. The analysis of these files delivers useful information about their state of health. They can come from various sources (physical servers, virtual servers, mobile applications, websites, etc) and can be counted in their millions each day - making them difficult to analyze. From your logs, you can draw valuable information about the behavior of your customers, or systems, and act accordingly.
How do I analyze my logs?
Logs Data Platform is a turnkey solution that enables you to collect, store, and analyze logs. It supports any type of log file; from application logs to server and security logs. There is the option to use your own choice of log collector (Syslog-ng, Fluentd, NXLog) or to use our dedicated collectors - Flowgger and Logstash - which work regardless of the source, format, or structure of your data. For log analysis, customers can leverage Graylog, Kibana, or Grafana visualization, to perform logs monitoring at the application level, or server monitoring when dealing with infrastructure supervision. The Logs Data Platform works as a powerful log analyzer solution by enabling customers to take advantage of the ELK (Elasticsearch Logstash Kibana) ecosystem.
How does the billing of a "logs account" work?
Logs Data Platform is an entirely pay-as-you-go model. You are not billed on the amount of data sent, but on the amount of data stored on the platform.
To use the Index as a service, do I have to take a shard?
Indeed, Elasticsearch shards (also called Shards) are essential for storing your documents. An Elasticsearch shard is 25 GB, and you can have up to 16 shards.
How many Roles, Streams & Dashboards am I eligible for?
You are entitled to as many Roles, Streams & Dashboards as you wish, at no extra cost (except Kibana).
Which protocols can I utilize to send my data?
You can push in TCP, TCP TLS or UDP.
How do alerts work?
We offer you the ability to set up Graylog alerts. These alerts can be based on present value status, a calculated numerical value, or the number of logs. Logs Data Platform will send you and your collaborators an email, so you can take action before it is too late. You can also easily integrate another alert system such as ElastAlert.
How do I access my SAP logs in OVHcloud?
For the feature enabling extraction and analysis of SAP logs via the OVHcloud Logs Data Platform to work, the operating system for your SAP environments (SUSE or RedHat) must be configured to ensure your SAP logs are collected and sent correctly to the OVHcloud Logs Data Platform. This process is automated (Ansible or Bash scripts provided) and documented and can be completed in just a few minutes.
Once the initial configuration has been completed, all your SAP logs will be accessible via the Logs Data Platform web interfaces (Graylog or OpenSearch Dashboards).
What does the Guarantee service consist of and what does it include?
If you have subscribed to the Enterprise offer, OVHcloud will make every commercially reasonable effort to ensure that access to the dedicated Logs Data Platform cluster (i.e. access to APIs, search and visualisation tools) is ‘Available’ during a given calendar month at a rate of over 99.9%.
If this is not the case, the customer will be entitled to request a service credit as described in the special terms and conditions for the Logs Data Platform service.
Which login details should I use to log in to Logs Data Platform?
To log in to Logs Data Platform, you no more need a specific identifier for your service. Thanks to IAM, you can log in directly with your OVH identifier. For more information, please go directly to the dedicated IAM page.
